This section contains statistical details for the Easy DOE platform.
• Easy DOE Design Selection Rules
• Statistical Details for Easy DOE Analyze Tab
The Easy DOE platform constructs designs using either the Custom or Definitive Screening Designers. The general rules are found in the table below. Additional rules determine when a definitive screening design is used.
Model |
Designer |
Main Effects |
Custom Design (D-Optimal) |
Main Effects with some Two-Factor Interactions |
Definitive Screening Design or Custom Design (Alias Optimal) |
Main Effects and Two-Factor Interactions |
Response Surface Design |
Custom Design (I-Optimal) |
The Easy DOE platform constructs a definitive screening design if all of the following are true:
• There are at least 5 factors
• All factors are either continuous or categorical
• All categorical factors have 2 levels
• There are at most 3 categorical factors
• The number of continuous factors is greater than or equal to the number of categorical factors
