To compute F-values and degrees of freedom, let p be the rank of
. Let q be the rank of
, where the L matrix identifies elements of
associated with the effect being tested. Let v be the error degrees of freedom and s be the minimum of p and q. Also let
and
Table 10.2, gives the computation of each approximate F from the corresponding test statistic.
Test |
Approximate F |
Numerator DF
Denominator DF
Wilks’ Lambda |
Pillai’s Trace |
Hotelling-Lawley Trace |
Roy’s Max Root |
