Data columns have numerous optional metadata attributes that can be set, queried, or cleared using the messages Get Property, Set Property, and Delete Property.
col << Set Property( "propertyName", {argument list} );
col << Get Property( "propertyName" );
col << Delete Property( "propertyName" );
The name of the property in question is always the first argument for Set Property, and what is expected for subsequent arguments depends on which property you set:
• Get Property and Delete Property always take a single argument, which is the name of the property.
• Get Property returns the property’s settings. Delete Property completely removes the property from the column.
• To get a list of all column property names for a column, specify the column and then use Get Properties List.
If you want to set several properties, you need to send several separate Set Property messages. You can stack several messages in a single JSL statement if you want.
col << Set Property( "Axis",{Min(50), Max(180)} )<< Set Property( "Notes", "to get proportions" );
To get a property’s value, send a Get Property message whose argument is the name of the property that you want:
Column("ratio") << Get Property( "axis" ); // return axis settings
To set columns as label columns:
dt << Set Label Columns( col1, col2, col3 );
To clear all label columns:
dt << Set Label Columns();
The same syntax works for Set Scroll Lock Columns, and Scroll Lock.
Tip: JSL choices for properties are the same as those in the Column Properties menu in the Column Info window. The arguments for each property correspond to the settings in the Column Info window. An easy way to learn the syntax is to establish the property that you want in the Column Info window first, and then use Get Property to view the JSL. See Set JMP Column Properties in Using JMP for more information about each property.
When writing JSL to script a column property, it is important to understand that the column is a repository for all column properties. The column stores the column property with the values supplied without evaluation or validation of the supplied arguments. In order to add column properties that contains variables using JSL code, the script must convert any variables to their actual values.
One way to do this is to use expressions. In the following example, the Eval Expr() function evaluates and replaces any variable wrapped in the Expr() function with its value. The outer Eval() function evaluates the entire statement after the replacement has occurred.
// assign desired spec limits
lLimit = 55;
uLimit = 70;
tLimit = 62.5;
Eval(
Eval Expr(
// store the limits in the Spec Limits column property
:height << Set Property("Spec Limits",
{LSL( Expr( lLimit ) ), USL( Expr( uLimit ) ), Target( Expr( tLimit ) ),
Show Limits( 0 )}
The Value Order column property specifies the order in which you want the data to appear in reports. Data can be sorted by numerical order, custom order, or by the order in which the data appear in the data table.
// numerical ordering sorts character column values by splitting
the data into string and numeric segments. The following example turns off
numerical order, which you might specify if the column contains character
data. Hex data ("A1FE2", "A13E4", "BEEEE") sort differently with numerical
ordering on or off).
:age << Set Property( "Value Order", {Numerical Order( 0 )} );
// specifies a custom order for the age column
:age << Set Property( "Value Order", {Custom Order( {15, 17, 12, 13, 14, 16} )} );
// sorts "ELIZABETH" first, the remaining items are sorted in alphabetical order
:name << Set Property( "Value Order", {Custom Order( {"ELIZABETH"} )} )
// specifies that if all values have a predefined sort order
// (for example, the days of the week), the remaining items are
// sorted on that basis. This option is available only for character data.
:age << Set Property( "Value Order", {Common Order( 1 )} )
// sorts the column values by their occurrence in the data table,
// rather than sorting by value
:name << Set Property( "Value Order", {Row Order Levels( 1 )} );
When you set the column property, you are setting the entire property. Suppose that you specify the row order levels. If the data happen to match a Common Order (for example, the days of the week), then Common Order takes precedence. In that case, you need to also include Common Order(0) in the property; you cannot send separate Set Property messages.
Table 9.4 shows examples for setting and getting popular column properties. See Set JMP Column Properties in Using JMP for more information about each property.
Property |
Description |
Example Using Arguments |
Notes |
Stores notes about a column. Is a quoted text string. |
col<<Set Property( "Notes", "Extracted from Fisher iris data" );
col<<Get Property( "Notes" ); |
List Check Range Check |
Prescribes the possible values that can be entered in a column. |
col<<Set Property( List Check,{"F","M"} );
col<<Set Property( "Range Check",LTLT(0, 120) );
col<<Get Property( "List Check" );
col<<Delete Property( "Range Check" ); |
Missing Value Codes |
Specifies column values that should be treated as missing. |
col<<Set Property( "Missing Value Codes", {0, 1} ); |
Value Labels |
Specifies labels to be displayed in place of the values. |
col<<Value Labels( {0 = "Male", 1 = "Female"} ); Use Boolean values to turn value labels on or off: col<<Use Value Labels( 1 );. |
Value Order |
Specifies the order in which you want the data to appear in reports. |
col<<Set Property( "Value Order", {"Spring", "Summer", "Fall", "Winter"} ); |
Value Colors and Color Gradient |
Specifies colors for either categorical or continuous data, respectively. |
Specify the color by assigning a JMP number to each value: col<<Set Property( "Value Colors", {"Female" = 3, "Male" = 5} ); Specify a color theme: col<<Set Property( "Value Colors", Color Theme( "White to Blue" ) ); If you omit the color theme, JMP uses the color theme preferences. Specify the gradient and the range and midpoint for Value Gradient: col<<Set Property( "Color Gradient", {"White to Blue", Range( {18, 60, 25} )} ); |
Axis |
Most platforms use this (if it exists) when constructing axes. Mostly Boolean. |
col<<Set Property( "Axis",{Min(50), Max(180), Inc(0), Minor Ticks(10), Show Major Ticks(1), Show Minor Ticks(1), Show Major Grid(0), Show Labels(1), Scale(Linear)} ); |
Units |
Provided for custom uses. Specify the units of measure. |
col<<Set Property( "units", "grams" );
col<<Get Property( "units" ); |
Coding |
Used for DOE and fitting. List with low and high values. |
col<<Set Property( "Coding", {59,172} );
col<<Get Property( "Coding" ); |
Mixture |
Used for DOE, fitting, and profiling. Specifies the Mixture column properties in a list. |
col<<Set Property( "Mixture", {0.2, 0.8, 1, L PseudoComponent Coding} );
col<<Get Property( "Mixture" ); |
Row Order Levels |
Specify to sort levels by their occurrence in the data instead of by value. |
col<<Set Property( "Row Order Levels", 1 ); |
Spec Limits |
Used for capability analysis and variability charts. |
col<<Set Property( "Spec Limits", {LSL(-1), USL(1), Target(0)} );
col<<Get Property( "Spec Limits" ); |
Control Limits |
Used for control charts. |
col<<Set Property( "Control Limits", {XBar(Avg(44), LCL(29), UCL(69))} );
col<<Get Property( "Control Limits" ); |
Detection Limits |
Set in DOE and used in generalized regression. |
col<<Set Property( "Detection Limits", {10, 50} ); |
Response Limits |
Set in DOE and used in desirability profiling. |
col<<Set Property( "Response Limits", {Goal("Match Target"), Lower(1,1), Middle(2,2), Upper(3,3)} );
col<<Get Property("Response Limits"); Choices for Goal are Maximize, Match Target, Minimize, None. Other arguments take numeric value and desirability arguments. |
Design Role |
Used for DOE. Specify a single role. |
col<<Set Property( "Design Role", "Covariate" );
col<<Get Property( "Design Role" ); Choices for role are Continuous, Discrete Numeric, Categorical, Blocking, Covariate, Mixture, Constant, Uncontrolled, Random Block, Signal, and Noise. |
Factor Changes |
Sets the difficulty of changing a factor (Easy, Hard, or Very Hard). |
col<<Set Property( "Factor Changes", Hard) ;
col<<Get Property( "Factor Changes" ); |
Sigma |
Used for control charts. Specify known sigma value. |
col<<Set Property( "Sigma",1.332 );
col<<Get Property( "Sigma" ); Each type of chart uses a different sigma calculation. |
Distribution |
Set the distribution type to fit to the column. |
col<<Set Property( "Distribution", Distribution( GLog ) );
col<<Get Property( "Distribution" ); |
Time Frequency |
Set the type of time frequency. |
col<<Set Property( "Time Frequency", Time Frequency( "Annual" ) );
col<<Get Property( "Time Frequency" ); |
Map Role |
Set how the column is used to connect map shape data with name data. Specify the role and other information as necessary. |
col<<Set Property( "Map Role", Map Role( Shape Name Use( "filepath to data table", "column name" ) ) );
col<<Get Property( "Map Role" ); |
Supercategories |
Groups specific categories into one category. Supported only in the Categorical platform. |
col<<Set Property( "Supercategories", {Group( "Genders", {"F", "M"} )} );
col<<Get Property( "Supercategories" ); |
Multiple Response |
Specifies the character that separates the responses within a cell. |
col<<Set Property( "Multiple Response", Multiple Response( Separator( "." ) ) );
col<<Get Property( "Multiple Response" ) ); Note: We recommend assigning the Multiple Response modeling type if the delimiter is a comma. Then you don’t have to specify the delimiter in the column property. See Multiple Response in Using JMP. |
Profit Matrix |
Assigns weights that define a decision model. Specify a list that contains the weights in a matrix and categories in another list. In the matrix, each row contains weights that reflect the profit for predicting the category indicated by the column of the matrix. Caution: The matrix argument is the transpose of the profit matrix as displayed in the Column Properties window. |
col<<Set Property( "Profit Matrix", {[5 -1, -1 4, -2 -2], {"F", "M", "Undecided"}} );
col<<Get Property( "Profit Matrix" ); |
Expression Role |
Applies to columns that contain expressions. Specifies whether the expression should be interpreted as a Picture, a Matrix, or an Expression. |
col<<Set Property( "Expression Role", Expression Role( "Picture", MaxSize( 640, 480 ), StretchToMaxSize( 1 ), PreserveAspectRatio( 1 ), Frame( 0 ) ) |
[Custom property] |
Provided for custom uses. Corresponds to Column Properties > Other in the Column Info window. The first argument is a name for the custom property, and the second argument is an expression. |
col<<Set Property( "Date recorded",12Dec1999 );
long date( col<<Get Property( "Date recorded") ); |
