Algorithmic Office of New Drugs Custom Medical Query Risk Report
This process uses OCMQs with associated algorithms together with data from DMSEX to query AE, LB, and CM for subjects meeting the specified qualifications and then calculates risk measurements for each query. Output is a two-sided plot with a dot plot showing percent occurrence and forest plot showing risk measurement along with a table listing number (and percentage) of subjects exhibiting each OCMQ by specific qualification.
The Office of New Drugs Custom Medical Query terms (OCMQs) are similar to SMQs and are the default version used in JMP Clinical. They are being promulgated by the FDA to further consolidate and standardize descriptions of medical conditions. Excel files containing OCMQs can be downloaded from https://www.fda.gov/drugs/development-resources/office-new-drugs-custom-medical-queries-ocmqs. Downloaded files should be saved to $DOCUMENTS\OCMQ\Version Number, where Version Number is the version of the FDA OCMQ xlsm file. If this folder doesn't exist, you must create it. When there are multiple versions of the OCMQs in the specified folder, you can use the Version of Office of New Drugs Custom Medical Query Files/Version of Standardized Medical Query Files widget on the Set Study Preferences window to specify which version of the OCMQs to use.
Note: Refer to Medical Query Type for more information on OCMQ files. This version consists of three JMP files that are automatically generated when JMP Clinical is installed. Modifications can be made for later versions of the OCMQs, but this requires modifications to the JMP tables.
Click below to view a video summary of this report or scroll to read detailed descriptions of the report results and options.
Report Results Description
Running Algorithmic OCMQ Medical Query Risk Report for a modified Nicardipine study using OCMQ v2.1 files generates the Report shown below.
The Report contains the following elements:
Risk Plot
There are two plots shown here. Medical queries are shown on the y axis. The dot plot on the left of each group shows the percentile occurrence of subjects in each arm exhibiting the queries. The Forest plot on the right of each group shows the risk difference for subjects to exhibit events covered by each query.
Forest Plots display relative strength of treatment effects as horizontal lines representing the 95% confidence interval of the effect observed in that trial. The confidence interval is normally for the relative likelihood of a given nominal-level outcome for the intervention group compared to the control group. In this example, the forest plot shown below, represents the risk difference for developing the specified event relative to exposure to Nicardipine.
Note: When you select either Relative Risk or Odds Ratio as the Risk Measurement, the scale on the x-axis of the Forest plot changes from linear to a log scale.
Sex-specific Risk Plot(s)
These plots are like the plots shown above but display sex-specific algorithmic OCMQs only. They are surfaced only when the Display sex specific algorithmic OCMQs separately option is checked.
In this example, a plot for female-specific algorithmic OCMQs is shown. A male-specific plot would also have been shown if any of the subjects had exhibited male-specific events.
Sex-specific Algorithmic Medical Queries Table(s)
This table is like the table shown above but lists sex-specific algorithmic OCMQs only. It is surfaced only when the Display sex specific algorithmic OCMQs separately option is checked.
In this example, a table for female-specific algorithmic OCMQs is shown. A male-specific table would also have been shown if any of the subjects had exhibited male-specific events.
This table lists each query with its associated qualifications, the number (percent) of subjects exhibiting the event by qualification, and the risk difference between the treatment arms.
You can click on the subjects displaying specific events described by the medical queries to bring up the Drill-downs tab that provides more details about the specific subjects and medical query along with several additional tables with more details.
Options
Data
Event Type
Analysis can consider all events or only those that emerge at specific times before, during, or after the trial period. For example, selecting On treatment events as the Event Type includes only those events that occur on or after the first dose of study drug and at or before the last dose of drug (+ the offset for end of dosing).
Ignore available treatment emergent flags
If you choose to ignore available treatment emergent flags, the analysis includes all adverse events that occur on or after day 1 of the study when the event type is Treatment emergent events.
Risk Measurement
Use the Risk Measurement option to specify the measure you want to use for defining risk.
Display Risk Difference as:
Use this widget to specify whether to display the risk difference values as either percentages or proportions.
Sort Risk Report plot and tables by:
Use the Sort Risk Report plot and tables by: widget to specify how the rows in the Risk Report plot and tables are to be sorted.
Treatment Value for Sort by:
Use this widget to specify the treatment value to sort the plots and tables by. This is especially useful when there are multiple treatment regimes. Refer to Treatment Value for Sort by for more information.
Calculate baseline using:
Use this widget to specify how the baseline findings measurements should be calculated. Refer to Calculate baseline using: for more information.
Check this option to display male-specific and female-specific algorithmic OCMQs in separate and distinct plots and tables. When this option is unchecked, sex-specific algorithmic OCMQS are included in the main plot and table.
Additional Filters
These filters let you restrict your analysis to only those subjects that meet specific criteria at the domain level. Applicable domains include Adverse Events (AE), Findings (LB), and Interventions (CM). Filters use JMP WHERE clauses to Select Rows that meet the specified criteria. To use these filters, you must enter the JSL (JMP Scripting Language) expressions that constitute the WHERE clause in the appropriate text box for specific filtering of AEs, Disposition, Findings, and/or Subjects. Note: This is an advanced concept that not only requires some basic knowledge of the JSL where clause syntax (similar to, but different from, SQL), but also an understanding of the exact variables in the tables in the study.
Note: To filter subjects with a specific event, one could also use the Subpopulation Builder on any domain of interest. For example, filter to all subjects that exhibit cardiac failure ( :Customized Query 01 Name == "Cardiac failure" ) and run all reports on those.
Report Data Filters
These filters enable you to subset and view subjects based on demographic characteristics and other criteria. Refer to Data Filter for more information.
Action buttons provide you with an easy way to drill down into your data. The following action buttons are generated by this report:
• Click to reset all report options to default settings.
• Click to view the associated data tables. Refer to Show Tables for more information.
• Click to generate a standardized PDF- or RTF-formatted report containing the plots and charts of selected sections.
• Click to generate a JMP Live report. Refer to Create Live Report for more information.
• Click to take notes, and store them in a central location. Refer to Add Notes for more information.
• Click to read user-generated notes. Refer to View Notes for more information.
Default Settings
Methodology
To run this report, at least two treatment levels are required, and the treatment control level preference must not be set to None.
Joining the OCMQ File with the Adverse Event Data Set
The algorithmic OCMQs are defined using three JMP tables that are saved to the OCMQ versioned folder. One table contains the criteria used to define each algorithm, one contains the preferred terms in each category for the hypersensitivity algorithm, and one contains the supplemental terms for the hypoglycemia algorithm. These tables are read into the report along with the OCMQ Excel file. The study data is then compared against the criteria defined in the JMP tables to determine which subjects meet each criteria.
The algorithms are taken from the Excel files that include the following queries: Abnormal Uterine Bleeding, Amenorrhea, Bacterial Vaginosis, Decreased Menstrual Bleeding, Erectile Dysfunction, Excessive Menstrual Bleeding, Gynecomastia, Hyperglycemia, Hypersensitivity, Hypoglycemia, Rhabdomyolysis. The seven sex-specific algorithms are defined using the SEX variable from either DM or ADSL. The remaining algorithms use a combination of the adverse events, laboratory findings, and concomitant medications datasets.
Statistical Calculations
This report calculates risk difference, relative risk, and odds ratio using the Response Screening platform in JMP. To prepare the data for this platform, a table is created with one row per subject and one column per medical query. Each medical query column is assigned a value of 1 if the query occurred for a subject and 0 if it did not.
These medical query columns are specified in the Y, Response role, and the treatment variable is specified in the X role. The calculated values for risk difference, relative risk, and odds ratio, along with their 95% confidence intervals, are saved from the 2 by M Results table.
Additional information on the Response Screening platform and the resulting statistics can be found at: https://www.jmp.com/support/help/en/19.1/?os=win&source=application#page/jmp/response-screening.shtml#.
Confidence intervals are calculated using JMP's Response Screening report. See Response Screening Report Tables and Confidence Interval for Two Independent Sample Proportions for more information.
Note: Records marked as not occurring (xxOCCUR = N) are excluded from this analysis.
