Quality and Process Methods > Variability Gauge Charts > Variability Gauge Platform Options
Publication date: 06/27/2024
The Variability Gauge red triangle menu contains the following options:
Save
Shows a submenu of the following options:
Save Metadata as Column Properties
(Not available if a By variable is specified in the launch window.) Provides the following options to save the metadata as column properties in the original data table.
You can save the metadata as MSA column properties.
You can compute and save the measurement sigma in the Process Screening column property. The measurement sigma is the square root of the total of all variance components subtracted by the part variance.
You can save the lower and upper tolerance values as Spec Limits column properties.
Save All Metadata to Table
Saves a new data table that contains the metadata for each column. This includes the measurement sigma, which is used in the Process Screening platform. The measurement sigma is the square root of the total of all variance components subtracted by the part variance. If there is a By variable, a table is saved for the corresponding level of the By variable and the table name includes the level.
Edit MSA Metadata
Opens a window that enables you to add or edit the tolerance range, tolerance limits, historical mean, and historical process sigma for all analyses. See Show MSA Metadata Entry Dialog.
See Local Data Filters in JMP Reports, Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Platform Preferences
Save Script
Save By-Group Script
