JMP reports are organized in a hierarchical outline. Each level of the outline has a triangle-shaped disclosure icon
that you can click to open and close report sections.
You can also change which columns appear in a report. Right-click the report and select the column from the Columns list. To select more than one column at once, press Alt before right-clicking.
