(Windows only) File Locations preferences set the default locations of JMP system files.
Figure 15.29 File Locations Preferences
Preference | Description |
Data Files directory | Change the folder in which JMP looks for data files (for example, data tables). |
License file path | Change the file path which JMP uses for your JMP License file. |
Preferences file directory | Change the folder in which JMP looks for preference information. |
Save As directory | Change the folder in which JMP saves data files when you select File > Save As. |
Always go to this directory when the File Open window is displayed | Select to have JMP always use the specified path when you select File > Open. |
