Output OptionsIn a Covering Array design, the Output Options section enables you to make a design table or to return to the design generation sections.
Make Table
Constructs the Covering Array data table.
Back
Takes you back to the Factors section. You can make changes to the previous sections and regenerate the design.
Note: If you have defined Disallowed Combinations in the Restrict Factor Level Combinations section, these are retained as a script. The script is shown in the Use Disallowed Combinations Script panel when you click Continue.
