Marker SimulationMarker Simulation simulates the progeny from a specified set of crosses using biallelic markers and predictor formulas (predictive models generated using the Response Screening platform) saved in your data table. This process enables you to test various crosses to estimate which crosses generate progeny with the desired combinations of traits.
Note: Specifying a large number of crosses, progeny, or both can consume considerable CPU and disk resources.
Figure 4.1 Example of the Marker Simulation PlatformÂ
The Marker Simulation platform is available only in JMP Pro.
