Make Validation Column Platform OptionsThe Make Validation Column red triangle menu contains the following options:
See Redo Menus in JMP Reports, Group Platform, and Save Script Menus in JMP Reports in Using JMP for more information about the following options:
Redo
Platform Preferences
Save Script
