JMP Live Resources
Publication date: 06/27/2024
JMP Live Resources
If your organization has purchased JMP Live, you can:
Publish reports to JMP Live. See Share Reports to JMP Live.
Publish data tables to JMP Live. See Share Data to JMP Live.
Access the JMP Live installation help at https://www.jmp.com/support/help/en/18.1/jmplive/jmpliveinstall.shtml.
Access the JMP Live user help at https://www.jmp.com/support/help/en/18.1/jmplive/jmplive.shtml.
Access the JMP Live administrator help at https://www.jmp.com/support/help/en/18.1/jmplive/jmpliveadmin.shtml.
Use the JMP Scripting Language to publish reports or data to JMP Live. See Publish Reports or Data to JMP Live.
