Some features in JMP are coded to take advantage of multiple central processing units (CPUs) on a machine, allowing these features to run significantly faster. This process is called multithreading.
The following features support multithreading:
Boosted Trees
Bootstrap Forest
• Choice
Covering Arrays
• Capability Analysis in Distribution
• Explore Outliers
• Explore Patterns
• Factor Analysis
• Fit Life by X
• Fit Model: Parametric Survival,
Mixed Model,
Generalized Regression, and
Response Screening
• Functional Data Explorer
• Gaussian (
Fast GASP and the use of Categorical variables are only in JMP Pro.)
K Nearest Neighbors
• Latent Class Analysis
• Life Distribution
• Multivariate
• Neural (
Some features are only in JMP Pro.)
• Nominal Logistic
• Nonlinear and Nonlinear Curve
• Normal Mixtures in Cluster Analysis
• Partial Least Squares (
• Partition
• Predictor Screening
• Principal Components
• Process Screening
• Profiler (Does not apply to Profilers launched from within other platforms.)
• Reliability Forecast
Repairable Systems Simulation
• Response Screening
Sparse Principal Components
Structural Equation Models
Support Vector Machines
• SVD Imputation in the Missing Values Screening
• Text Explorer (
• Time Series Forecast
Uplift
• Variable Clustering
