Functional ResponseThe FDE X column property specifies a column as a functional response. Functional responses are defined when building a designed experiment. The column property is not listed in the column property menu. The property is set by a DOE platform. Multiple Y columns with the FDE column property can be used in the Functional Data Explorer platform with the DOE factors as supplementary factors.
