Frequent Item SetsThe Frequent Item Sets report in the Association Analysis platform lists item sets in decreasing order of support. The listed item sets meet the Minimum Support value that you specified in the launch window. Each item set is considered as a conditional and as a consequent item set to form association rules. The table contains the following columns:
Item Set
The item sets that are considered as conditional or consequent sets for the association rules.
Support
The proportion of transactions in which all of the items in the Item Set occur.
N Items
The number of items in the Item Set.
