Display cross-tabulation tables of Baseline versus Trial laboratory measurement elevations
Check this box to compute and display tables of subject counts and percentages (per treatment group) of laboratory elevations in reference to the upper limit of normal (LBSTNRHI) for measurements taken at baseline versus trial summary measurements. Each table can be interpreted as a categorized representation of the shift from baseline.
Caution: This option doubles the number of columns in the output data set. If you have many laboratory tests and these tables are not desired in the output, you should uncheck this box to improve processing and results generation speed.
Each crosstabulation table contains the applicable set of the following categories:
• Less than 2x ULN
• 2x and 5x ULN
• 5x and 10x ULN
• 10x and 20x ULN
• 20x ULN or Greater
• Missing
• All
To Specify This Option:
8 Ensure that LB is chosen for Findings Domain to Analyze.
8 Ensure that ULN is chosen for Normalization of Lab Measurements.
8 Ensure that the box is checked.
Example
Refer to LB Shift Tables for sample output corresponding to this option.
