Lab Test Short Name for Glomerular Filtration Rate
Use this text field to specify the Test Short Name (LBTESTCD) value that corresponds to the glomerular filtration rate test.
By default, the report attempts to detect common recommended values for the glomerular filtration rate test. If it finds one, the report automatically enters it in the text box. If an alternative designation is used in your study, the field is left blank and you must specify the designation.
To Specify a Short Name for the Glomerular Filtration Rate Test:
8 Click to open the Add window that lists available test names.
8 Select the designation for the glomerular filtration rate test and click to add the test name to the text box.
