Include on-study lab tests where reference range indicator is:
Use this option to select the on-study lab tests, based on reference range indicators, to include in the narrative.
Available options are described in the following table:
Option: |
Select when you want to: |
Abnormal with normal baseline |
Different Compared to Baseline |
Note: On-study measurements specify the baseline flags (for example, low BUN [2.142 mmol/L, range = (2.499 - 7.497), BL =normal]), but baseline values are printed only when abnormal to begin with. |
Abnormal Regardless of Baseline |
To Specify This Option:
| 8 | Make sure that the Include a findings domain in the narrative box is checked and LB is selected in the option. |
| 8 | Click the radio button corresponding to the desired indicator. |
