Review Subject Filter
The Review Subject filter is surfaced on the left side of all reports. It enables you to filter the population based on selected demographic or other parameters. Selections made are applied to all reports across the review.
8 Use the Data Filter to specify criteria for including subjects to explore. Only those subjects meeting the filtering criteria are shown in the subject list.
8 Click to select a subject and use drill down buttons for further analysis. Use Ctrl-click to select multiple subjects.
8 Click to select additional columns to filter the subjects.
If you save the template, all selections in report filters and the review subject filter are saved. In addition, a new message is added just below the report title whenever a review subject filter is in effect. That message contains the where clause that is applied to the subject population. Every report that responds to the review subject filter will have the where clause message.
Note: Templates can be used across studies. If you apply a template to a study that lacks the variables selected in the saved report filter(s) and/or review subject filter, those filter(s) won't be applied to the new study. In that case, the default filter(s) without selections for the report is applied.
