Supplemental JMP Data Table for RBM
Specify the full path and name to the input JMP data table containing supplemental data for risk based monitoring.
Note: This data table should be formatted using the CDISC-like standard for RB.
Risk Based Monitoring (RBM) supports site-level variables in the supplemental data table. These are identified by having USUBJID missing. Study Site Identifier (SITEID) is now a required variable for this format. Within the same analysis, subject and site-level variables cannot share the same values for VARIABLE and RBDECOD. Refer to Risk Based Monitoring Supplemental Data Table for more information about supplemental data sets used for RBM.
To Specify the Supplemental Data Set:
| 8 | Click and then navigate to the location of the data set. |
To View the Contents of the Specified Data Set:
| 8 | Click . |
