Group Level
Use this option to specify the level for grouping preferred terms or verbatim terms.
Possible group levels are listed in the following table:
Group Level
Corresponding Variable
Function
Body System
AEBODSYS in AE
• Uses a dictionary-derived text description of the affected body system, listed in the AEBODSYS column in AE.
Higher Level Term (HLT)
AEHLT in AE
• A superordinate descriptor for multiple preferred terms (PTs).
Higher Level Group Term (HLGT)
AEHLGT in AE
• A superordinate descriptor for multiple higher level terms (HLTs)
Standard MedDRA Query
• Grouping of MedDRA terms, at a defined level, that describes a specific medical condition.
Primary System Organ Class (SOC)
AESOC in AE
• Uses Primary System Organ Class level of adverse events as categories.
Lowest Level Term (LLT)
AELLT in AE
• Uses Lowest Level Term level of adverse events as categories.
Body System or Organ Class
AEBODSYS in AE
• Uses body system or Organ Class level of adverse events as categories.
Dictionary-Derived Term
AEDECOD in AE
• Uses Dictionary-Derived Term level of adverse events as categories.
Reported Term for the Adverse Event
AETERM in AE
• Uses Reported Term for the Adverse Event level of adverse events as categories.
Category
CMCAT in CM, or SUCAT in SU
• Uses Category level of interventions as categories.
Category for Medication
Multiple domains use this parameter. Not all group levels are available in all of the reports in which term levels are specified.
In some reports, options are dynamically populated by available terms (with the list filtered based on hierarchically appropriate group levels).
