Select the analysis population
Use the drop-down menu to select the set of individuals to include in the analysis.
This list is populated with available populations that can be defined for the current Study based on flags found in the ADSL, ADDM, or DM (and optionally SUPPDM) data sets. Possible populations are listed in the following table:
Select this population: Note: One or more of these options may not be available, depending upon the report you are running.
When you want to include: |
All Subjects Excluding Screen Failures |
Subjects with values Screen Failure in either ARM or ACTARM, or SCRNFAIL in either ARMCD or ACTARMCD are considered screen failures. Note: Values indicating screen failure must be specified exactly as listed. Refer to How is JMP Clinical affected by localization-specification? for exact specifications in all languages supported by JMP Clinical. |
All Subjects |
Safety |
Note: This is the default selection if the population exists. |
Full Analysis Set |
Intent-to-Treat |
Per-Protocol |
Completers |
Randomized |
Enrolled |
