Glossary
| Term | Definition/Explanation |
CDISC Analysis Data Model. |
Significance level. Denotes Type I Error rate. Although alpha can be any value between 0 and 1, it is typically set at either 0.01, 0.05 or 0.10. |
A position that a researcher evaluates in an experiment. The alternative hypothesis, H1 (or Ha), is the hypothesis that sample observations are influenced by a specific non-random cause. It is rival to the Null Hypothesis, H0. |
Analysis of covariance; a general linear model with a continuous outcome Variable and multiple predictor variables, with at least one nominal and one continuous predictor variable. Considered a hybrid of regression for continuous variables and ANOVA, ANCOVA can determine whether specific factors have an impact on the outcome variable after removing variance resulting from Covariates (the qualitative predictors). |
Statistical models and procedures that partition observed Variance in a Variable into components attributable to different variation sources. By analyzing comparisons of variance estimates, ANOVA can determine whether the Means of several groups are statistically equal. |
Denotes Type II Error rate, and is related to the Power of a test (power = 1-beta). |
A group of related or functionally similar Observations that are considered as a unit for statistical analysis. |
A Variable that contains two discrete values (0 and 1, for example). |
Involving two Variables. |
A group of organs that work together to perform a task. Examples in humans include the digestive system, the nervous system, and the endocrine system. |
All of the Observations with the same values for all BY Variables. |
An optional (in most reports) Variable specification whose values define groups of Observations, such as hour, month, or year. Specifying a BY variable enables you to animate an image so that you can see how response values change according to some grouping, like over time. Alternatively, BY variables can enable analyses to be performed separately on different groups as defined by a variable such as gender. |
Clinical Data Interchange Standards Consortium, a nonprofit organization that has “established standards to support the acquisition, exchange, submission, and archive of Glossary data and Metadata” whose mission is “to develop and support global, platform-independent data standards that enable information system interoperability to improve medical research and related areas of health-care”. See the CDISC website for more information. |
These columns specify those Observations for which data have been censored or truncated. For example, investigations of the effects of certain genes on life span might be terminated before all of the individuals have expired. The ultimate life spans for these individuals are unknown. All that can be said is that they exceed the period of the study. These data are considered censored. |
A Variable whose values can consist of alphabetic and special characters as well as numeric characters. |
A statistical test used to test the existence of a relationship between two nominal Variables where the sampling distribution of the Test Statistic is a chi-squared distribution when the Null Hypothesis is true (or where it is asymptotically true). |
The Variable whose values define the groups for analysis. Class variables can have continuous values, but they typically have a few discrete values that define the classifications of the variable. Values can either be character or numeric. |
The process of dividing a data set into mutually exclusive groups such that the Observations for each group are as close as possible to one another, and different groups are as far as possible from one another. |
A statistical test used for repeated tests of nominal variable independence. |
A relationship between Variables in terms of dependence. |
Also known as the Pearson product-moment correlation coefficient, it is equal to the Covariance of two Variables divided by the product of their Standard Deviations. |
A measure of the relationship between two Variables. It equals the Correlation Coefficient between the two variables times the square roots of their Variances. |
An Independent Variable, not manipulated by the experimenter, that can influence the outcome of the experiment. |
A tree-like diagram used to summarize a Clustering report. A dendrogram shows where each cluster divides in a hierarchical fashion. See Heat Map and Dendrogram. |
A Variable whose value is determined by the value of another variable or by the values of a set of variables. This variable lists the responses you measure. In a two-dimensional plot, the dependent variable is usually plotted on the y (vertical) axis. |
Graphics showing the number or proportion of events falling within a particular interval. JMP Clinical software presents these distributions as histograms or Parallel Plots. See Distribution. |
Double False Discovery Rate (FDR) Adjustment |
The Double FDR method of Mehrotra and Heyse (2004)1 is used to compare the incidence of adverse events among treatments, leveraging the grouping of related adverse events (typically defined by the MedDRA system organ class). The method considers whether related terms within a group show differences between the treatments and upweights or downweights the significance of an individual term within the group accordingly. In the 2004 paper, the FDR adjustment is performed twice, and simulations are used to control the false discovery rate. Mehrotra and Adewale (2011) refine the Double FDR method to avoid the need for simulations by applying FDR adjustment thrice. |
The distance between two points that would be measured with a ruler. It is derived from the Pythagorean equation: a2 + b2 = c2. |
Also referred to as an Independent Variable or predictor variable, a factor is a Variable included in a model to account for variation in a response. Factors are the variables whose values (levels) you set to study their relationship to a response. You often experiment with many potentially influential factors at the same time. |
The expected percentage of a set of predictions that are assumed to be false. For example, if an analysis, which predicts the association of 10 genes with a particular trait has a false discovery rate of 0.1, you can expect 9 of the predictions to be correct. |
The probability of making one or more false discoveries (Type I Errors) among all hypotheses while performing multiple pairwise tests. |
A graphical display designed to illustrate the relative strength of treatment effects in multiple quantitative scientific studies (or databases) addressing the same question. Forest plots generally display results for each study (or other data source) as horizontal lines representing the 95% confidence interval of the effect observed in that trial. See Forest Plot. |
The nth root of the product of the data. The statistic is helpful when the data contains a large value in a skewed distribution. |
A Variable that is used for grouping results. |
A heat map is a visual representation that shows the intensity of a phenomenon as color in two dimensions. It is drawn as a rectangular array of cells with each cell corresponding to a data table entry. Colors are assigned to each cell based on the range and type of values. |
A method of cluster analysis that constructs a hierarchy of clustering. Strategies include the agglomerative approach, where each cluster initially contains only one observation, and the divisive approach, where all observations are initially contained in one cluster. Hierarchical clustering results are commonly presented in Dendrogram form. |
The second-highest level of the Medical Dictionary for Regulatory Activities (MedDRA) Hierarchy, below System Organ Class (SOC) and above High Level Term (HLT). An example of an HLGT is “Respiratory tract infections”. |
The third-highest level of the Medical Dictionary for Regulatory Activities (MedDRA) Hierarchy, below High Level Group Term (HLGT) and above Preferred Term (PT). An example of an HLT is “Viral upper respiratory tract infections”. |
A test of the Null Hypothesis that “the population Mean vector is equal to the given mean vector”. It is the multidimensional equivalent of the one-sample t-test. |
A decision-making rule based on data from an experiment or observational study. A hypothesis test is used to conclude significance of a result based on the sufficiently low likelihood (set by the predefined significance level) that it occurred because of random chance alone. |
An ominous prognostic indicator that a pure drug-induced liver injury (DILI) leading to jaundice, without a hepatic transplant, has a case fatality rate of 10-50%. |
The computation of replacement values for missing input values. |
This Variable does not depend on the value of another variable; it represents the condition or parameter that is manipulated by the investigator. In a two-dimensional plot, the independent variable is usually plotted on the x (horizontal) axis. |
One or more columns specifying how the Observations are to be classified. |
In JMP, a journal is a file (.jrn) that contains results of user-specified reports. |
A curve based on the survival function estimator from life-time or clinical outcome data. For example, it can be used to measure the proportion of subjects living for a given amount of time after treatment, or to measure the time until a tumor disappears. |
The lowest level of the Medical Dictionary for Regulatory Activities (MedDRA), below Preferred Term (PT). This level is reserved for non-current, vague, ambiguous, truncated, or misspelled terms, or for terms taken from other terminologies that do not conform to MedDRA rules. |
Least squares Means, which are estimates of means of classification effects that would be observed, assuming that the experimental design is balanced. |
A distance measure based on Correlations between Variables. In contrast to Euclidian distance, it is better adapted to non-spherically symmetric distributions, and is scale-invariant. See Mahalanobis Distances. |
An effect measures the extent to which the response depends on the factors involved in the effect. A main effect is the change in the response due to a single factor. For two-level factors, the main effect is the difference between the mean response at the high level of a factor and the Mean response at its low level. |
Mathematical average for a collection of n Observations. It is calculated by dividing the sum of the observations by n. |
In any set of n Observations arranged in order of magnitude, the median is represented by the observation positioned at n/2. |
A formula or algorithm that computes output values from input values. |
A graphical representation of a two-way frequency table or contingency table. A mosaic plot is divided into colored rectangles, so that the area of each rectangle is proportional to the proportions of the Y Variable in each level of the X Variable. See Mosaic Plot. |
A Variable that contains discrete values that do not have a logical order. Includes names and other verbal descriptions. |
A general or default position that a researcher tests (and attempts to reject) in an experiment. The null hypothesis, H0, is an essential part of a research design, and usually proposes that sample Observations result purely from chance. The null hypothesis can never be proven; data can reject it or fail to reject it only. If a null hypothesis is rejected, an Alternative Hypothesis, H1 (or Ha) is accepted. |
A Variable that contains only numeric values and related symbols, such as decimal points, plus signs, and minus signs. |
A row (horizontal component) in a table. Each observation contains one data value for each Variable in the data set. |
Analysis of variance with one between-groups factor. This is useful when you have a nominal Independent Variable and a normally distributed interval Dependent Variable, and you want to compare differences in the means of the dependent variable according to levels of the independent variable. |
A plot showing the response points along the Y axis for each X factor value. Using the plot, you can compare the distribution of the response across the levels of the X factor. The distinct values of X are sometimes called levels. See One-way Plot. |
A Variable that contains discrete values that have a logical order. For example, a variable called Rank could have values such as 1, 2, 3, 4, and 5. |
A plot showing several lines or markers on the Y axis overlaid to a common variable on the X axis. See Overlay Plot. |
A plot consisting of connected line segments across all responses for each row in a data table. See Parallel Plot. |
The value of a Variable below which a certain percent of Observations fall. For example, the 60th percentile is the value below which 60% of the observations can be found. Note the following percentile landmarks. - 25th percentile = first quartile = Q1 - 50th percentile = second quartile = median = Q2 - 75th percentile = third quartile = Q3 |
The conditional probability of a random event that is assigned after relevant evidence is considered. Contrast with Prior Probability. |
The probability of a statistical significance test enabling you to reject the Null Hypothesis when the Alternative Hypothesis is true. Power equals one minus Beta (the rate of Type II Error). |
The fourth-highest level of the Medical Dictionary for Regulatory Activities (MedDRA) Hierarchy, below High Level Term (HLT) and above Lowest Level Term (LLT). An example of a PT is “Influenza”. |
The probability of an event computed before collection of new data (often based on an experienced expert opinion or rules-of-thumb). An experimenter begins with a prior probability of an event and then revises it in light of new data. Contrast with posterior probability. |
The statistical probability that a Statistic is as or more extreme than the observed value, assuming that the Null Hypothesis is true. A smaller p-value enables you to more rigorously reject the null hypothesis. |
Techniques for modeling and analyzing several Variables, with the focus on the relationship between dependent and independent variables. Regression analysis is useful in uncovering how values of a Dependent Variable change when a single Independent Variable is varied. |
The number of Observations that constitute a statistical sample. For example, the sample size in a study might consist of the number of subjects. Greater sample sizes lead to greater precision and Power for a study design to detect an effect at a given size. |
A graph showing the relationship between two Variables. Multiple scatterplot formats exist, including scatterplot matrices and three-dimensional scatterplots. |
A subject in a Clinical Research study that skips treatments or otherwise does not meet treatment criteria. In clinical data sets, a value of “Screen Failure” is given in the treatment column for this subject. |
CDISC Study Data Tabulation Model. Refer to the CDISC website for more details. |
A graphical display enabling you to compare how an experimental population responds to an experimental treatment. See Shift Plot. |
A statistical measure of how “spread out” the data are. It is calculated by taking the positive square root of the sum of the squared deviations of each Observation from the sample Mean divided by (n-1). |
The standard deviation of the sample mean. It is calculated by dividing the Standard Deviation by the square root of the Sample Size. |
Standardised MedDRA Queries (SMQs) are used to support signal detection and monitoring. SMQs are validated, standard sets of MedDRA terms. Some SMQs are a simple set of Preferred Terms (PTs) while other SMQs are hierarchical containing subordinate SMQs. SMQs include narrow, broad and algorithmic terms. |
Multiple meanings are possible: - Transformation of a data set to have zero Mean and unit Variance. - Making all regression coefficients have the same scale. - Normalization. |
A Variable that partitions the data into blocks with similar characteristics. |
Plots of survival functions estimated for each subject. See Survival Curves. |
A plot summarizing the survival of subjects in each experimental ARM over the course of a Clinical Research trial. See Survival Plot. |
The highest level of the Medical Dictionary for Regulatory Activities (MedDRA) Hierarchy, above High Level Group Term (HLGT). An example of an SOC is “Respiratory, thoracic, and mediastinal disorders”. |
Test Statistic |
A function of the data sample that reduces and summarizes the data to either one or a few values that can be used to conduct a Hypothesis Test. |
The process of applying a function to a Variable in order to adjust the variable's range, variability, or both. |
A measure of how extreme a statistical estimate is. It is calculated by subtracting a reference of hypothetical value from your estimate and then dividing the remainder by the Standard Error value for the experiment. |
A test that assesses the statistical difference between the Means of two different experimental groups. The Test Statistic follows a Student’s t distribution if the Null Hypothesis is supported. If only one Variable is chosen (one-sample t-test), the null hypothesis is that “the population mean is equal to the given mean”. |
An incorrect decision made when a test rejects a true Null Hypothesis (H0). This is comparable to a false positive error. Type I error rate is denoted by Alpha, and is referred to as the size of the test. |
An incorrect decision made when a test fails to reject a false Null Hypothesis (H0). This is comparable to a false negative error. Type II error rate is denoted by Beta, and is related to the Power of a test (power = 1-beta). |
A column (vertical component) in a data set. The data values for each variable describe a single characteristic for all Observations. |
A measure of deviation of a group of samples from the mean. It is calculated by squaring the Standard Deviation. |
A Scatterplot of the negative log10-transformed p-Values derived from a specific t-test against the log2-fold change in expression. Decreased responses lie to the left of the Mean; increased responses lie to the right of the mean. See Volcano Plot. |
A series of processes run in a specified order, whose output is collected in a Journal. Given a constant basic experimental design and analysis objectives, a workflow can be used repeatedly with different data sets. |
