Summary Statistics to Display in Tables
Select the summary statistics to display in the Findings tables.
Default selections include number of samples, mean, standard deviation, minimum value, median, and maximum value.
Options are listed in the following table:
Summary Statistic
Definition
N
• Reports the number of findings across the trial period
Mean
• Reports the mean of all findings measurements observed across the trial period.
• This value is always used to summarize data from the baseline period.
StdDev
• Reports the standard deviation of all findings measurements observed across the trial period.
Min
• Reports the minimum value observed across the trial period.
Median
• Reports the median of all measurements observed across the trial period.
Max
• Reports the maximum value observed across the trial period.
StdErr
• Reports the standard error for all findings measurements observed across the trial period.
CV
• Reports the coefficient of variation for all findings measurements observed across the trial period.
Quantiles(25)
• Reports the cutoff for the lower quartile for all findings measurements observed across the trial period.
Quantiles(75)
• Reports the cutoff for the upper quartile for all findings measurements observed across the trial period.
By default if nothing is selected the following statistics are shown: N, Mean, Std Dev, Min, Median, and Max.
To Select the Summary Statistics to Be Displayed:
8 Click to open the Add window that lists available statistics (shown below).
Note that the statistics already selected are in italics.
8 Select the additional statistics you want to idisplayed and click to add those statistics to the text box.
In this example, visits standard error was selected and added.
8 To select multiple statistics, click on each desired statistic while pressing and holding the Ctrl key.
