Time Window Method
Use the radio buttons to choose the method for determining the time points at which to plot the change from the baseline.
Available methods are described in the following table:
Method for Determining Time Points
Definition
None
• Select this option to not use time windows.
Set Number of Time s
• Select this option to divide the trial period into intervals of equal length. The number of intervals is specified using the Number of Time Windows field or slider.
• All observations taken within an interval are plotted together.
Use Time s list
• Select this option to plot observations taken at specific times during the trial period. Times are specified as a list in the Trial Time Windows field.
• Observations not corresponding to one of the s are deleted from the analysis.
Note: Either Days or Weeks must be specified as the Time Scale before this option can be used.
To Specify the Method Used for Determining Time s:
8 Click the radio button corresponding to the time frame that you want to use.
