Duration Time Window Method
Use the radio buttons to choose the method for determining the time s to consider during analysis of exposure duration.
Available methods are described in the following table:
Method for Determining Time Points
Definition
Set Number of Duration Time s
• Select this option to divide the total exposure period into intervals of equal length. The number of intervals is specified using the Number of Duration Time Windows field or slider.
• All observations taken within an interval are plotted together.
• The final report lists the number of patients that fall into each of exposure.
Use Duration Time s List
• Select this option to plot observations taken during specific time points during the trial period. Time s are specified as a list in the Duration Time Windows field.
• The final report lists the number of patients that fall into the specified s of exposure only.
To Specify the Method Used for Determining Time Points:
8 Click the radio button corresponding to the time frame that you want to use.
