Term Level
Use this option to specify which level of terms (for example, adverse event, intervention, or MedDRA) to use as categories.
Possible term levels are report-specific and are listed in the following table:
Term Level1
Corresponding Variable
Function
Preferred Term (PT)
AEDECOD in AE
• Uses a dictionary-derived text description of the adverse event, listed in the AEDECOD column in AE, that defines the corresponding value in the AETERM or AEMODIFY column.
• A preferred term is restricted to a single medical concept.
Verbatim Term (VT)
AETERM in AE
• Select this option to use the term as listed in the adverse event term variable.
• Verbatim terms are identified by values within the reported term (AETERM) variable of AE.sas7bdat data set.
Body System
AEBODSYS in AE
• Uses a dictionary-derived text description of the affected body system, listed in the AEBODSYS column in AE.
Higher Level Term (HLT)
AEHLT in AE
• A superordinate descriptor for multiple preferred terms (PTs).
Higher Level Group Term (HLGT)
AEHLGT in AE
• A superordinate descriptor for multiple higher level terms (HLTs)
Standard MedDRA Query
• Grouping of MedDRA terms, at a defined level, that describes a specific medical condition.
Primary System Organ Class (SOC)
AESOC in AE
• Uses Primary System Organ Class level of adverse events as categories.
Lowest Level Term (LLT)
AELLT in AE
• Uses Lowest Level Term level of adverse events as categories.
Body System or Organ Class
AEBODSYS in AE
• Uses Body System or Organ Class level of adverse events as categories.
Dictionary-Derived Term
AEDECOD in AE
• Uses Dictionary-Derived Term level of adverse events as categories.
Reported Term for the Adverse Event
AETERM in AE
• Uses Reported Term for the Adverse Event level of adverse events as categories.
Reported Name
either CMTRT (for Concomitant Medications) or SUTRT (for Substance Use)
• Uses Reported Name level of intervention as categories.
Standardized Name
either CMDECOD (for Concomitant Medications) or SUDECOD (for Substance Use)
• Uses Standardized Name level of intervention as categories.
Note: The dictionary name and version used to generate the descriptions should be included as part of the submission.
To Specify the Term Level:
8 Select the term level corresponding to the adverse event terms that you want to use from the drop-down menu.
