Summary Statistic for Findings Data
Use the drop-down menu to select the statistic used to summarize the data from the LB, VS, and EG domains.
Options are defined in the following table:
Summary Statistic
Definition
Min
• Reports the minimum value observed across the trial period.
Mean
• Reports the mean of all measurements observed across the trial period.
• This value is always used to summarize data from the baseline period.
Median
• Reports the median of all measurements observed across the trial period.
Max
• Reports the maximum value observed across the trial period.
Last
• Reports the last value observed across the trial period.
To Specify the Statistic Used to Summarize the Data:
8 Check the Create summary statistic variables for numeric findings box to activate this field.
8 Select the summary statistic that you want to use from the drop-down menu.
